Configures the managed address configuration flag value sent in router discovery advertisements on the VLAN.
| vlan_name | Specifies an IPv6 configured VLAN. |
| on_off | Specifies setting the flag to on or off. |
Off.
This command configures the contents of the managed address configuration flag in the router advertisement messages.
A value of on tells hosts to use the administered (stateful) protocol DHCP for address autoconfiguration in addition to any addresses autoconfigured using stateless address autoconfiguration. A value of off tells hosts to use stateless address autoconfiguration. If this command is not entered, the default value is off.
The following example configures the managed address configuration flag to be on for the VLAN "top_floor":
configure vlan top_floor router-discovery managed-config-flag on
This command is available on the platforms listed for the IPv6 unicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
